ranman5608
- Jan 23, 2023
- 119
- 164
Hey glamis fam just wanted to show off my work in progress.
I picked this car up not too long ago and decided to make a few changes. Below are some specs.
Chassis: 4 seat Baja Shop with a Jimco class 1 or 10 front bulkhead A arm front end.
Engine: turnkey ls6 on mefi 4b ecu
Transmission: deco case mendeola md4s-2d and jamar x shifter
Shocks: fox racing 2.0 coil over 2.5 bypass front. sway a way 2.5 coilover fox 3.0 bypass rear.
Hubs & Brakes: front RBP 2.0 4 piston willwood calipers. rear Summers brothers full float 934 with 6 piston jamar x calipers. Full hanging pedal assembly with jamar masters and turning brake
Seats and Belts: PRP and PRP 5.3 harnesses
Coms: PCI intercom iCOM radio
Lighting: rigid pods on front bumper and a pillar rigid light bar on roof safeglo led interior lights and dual marshin whips
Gps: Lowrance 3300 (old unit but works well)
Wheel & Tires: desert setup 15” douglas bead locks 33” BFG mid terrains. Sand setup 15F-17R black douglas bead lock with razor blasters and sand blasters
now the changes
I first pulled off the old wrap which was starting to get pretty dry and look bad then I edited a profile view of the car for concept (picture of the two white profile views) I was never really fond of the slant roof look so I decided to chop it down a few inches. Once that was completed I cut a new roof and added a couple led dome lights. Next I figured I would make a new exhaust since the packing in the driver side muffler was deteriorating I decided to go to an exotic style center exit which sounds amazing now. I then cut a new glass for the windshield and broke a couple of them during the installation so since I will be re coating the entire car eventually I powder coated the windshield frame for the last one because I didn’t want to pull the glass back out until completely necessary. Once all of that was completed I had the Tatum steering rack rebuilt and replaced all of the consumable hardware in the front end. Now next step is to service all of the drivetrain components. I also included a graphics idea I’ve been toying with and an idea for the interior panels and roof (this stuff should deaden the sound greatly.
hope you guys like her let me know if you have any questions.
now the changes
