Orange_R
- 993
I'm in Norco and have a handheld scanner you can useNo start with the ICP off and not using oil.....Stumper for sure... thinking maybe IDM..... bad IPR..... Need a scanner for sure.
I would start thinking idm or hpop failure. Is your ebp valve in closed position by chance? The pcm takes input from ebp, ipr, icp, and cps sensors on startup, as well as fuel bowl heater for some reason (check that fuse #22 not blown) Low voltage on any one sensor and injectors wont fire. Truck needs oil pressure and fuel pressure to run. Did you check for 60psi cranking fuel pressure? Just because there is fuel in the bowl doesnt mean there is enough psi to fireNo start with the ICP off and not using oil.....Stumper for sure... thinking maybe IDM..... bad IPR..... Need a scanner for sure.
Thanks... I'm sending it to Domestic in chino tomorrow....they are fair and honest. I'm over it at this point. I checked all the normal stuff... thanks for the help...I'm in Norco and have a handheld scanner you can use
I would send it to C&S long before I ever gave anymore money to John at Domestic... that dude is the king of upsell and clean out your accountThanks... I'm sending it to Domestic in chino tomorrow....they are fair and honest. I'm over it at this point. I checked all the normal stuff... thanks for the help...
Yep, I haven't seen that anywhere either. The shop even sounded surprised by the truck starting.... We shall see I guess.Huh, not too sure. Never heard of that. I’ve never had a CEL with a cps issue. Infact my ‘97 NEVER threw a code ever. even with fuel pump failure. Glad it was something simple.
Domestic Diesel! John is good people and staff is great.She started taking longer to start....then yesterday she started , ran about 5 seconds, then died, then 20 seconds, then 10, then she fired up with some throttle....ran ok drove her down the block then into the driveway....idled for a minute or two, then died, now no start...
turns over tach works, fuel bowl is full, changed cps....pulled chip,
Anybody in the Norco IE area work on these still? 145k miles, HPOP is an adreneline pump, IPR has like 20k miles on it. new harness under fuel bowl. Who's the expert?
Ipr is like 270$ with pigtailWell, it started actiing up for them and they said the IPR is acting up... so 1200 and we'll see where it goes...
when i had the code on my 96 the cps went out, put in a new one and it fired right up, code still in for months until I remembered to clear it.Well Update #1.... shop called.... the put the scanner to her, she had a CPS sensor code stored.....I had replaced it with the new "C" model cps, so they cleared that code and cranked her and she started..... and kept starting...and won't die on them.???????? Good and bad I guess.....
Do any of you know if a stored CPS code would have kept it from starting???
They are going to keep it for a few and drive it and see if they can get it to die.... Just friggen weird....
The Harness is new... so with the full scan time and the IPR and replacement we are there... he wanted to do the fuel lines too , but I replaced them when I got the truck so they have like 40k miles on em....He's gonna look at them and see what they look like.Ipr is like 270$ with pigtail
….i’ve noticed they can be fine cold and problematic at operating temperature. But you may be looking at an idm issue if ipr doesnt fix it
i went with the strictly diesel full race fuel set up, man what a nice kit, pricey but it was really easy to do and had every part you need.I think they were real live scanning it because he said they saw the IPR problem when it started acting up... so hopefully...she's good for another 150k.
pcm is on the driver side kick panel and are prone to water intrusion from the windshield, so when you get the new pcm you might have your windshield gasket replaced also.Well, that dreaded call...well the IPR wasn't the problem.... so it died, they swapped out a pcm and it runs..... put the old pcm back in and dead again...so now it's pcm time.
