- Apr 29, 2021
- 6,733
- 7,447
Do it.
I always go to g&j for hoses and fittings. I also will use push lock stuff that I get from Kartek.I really need to get back to this, anyone here versed on AN fittings and sizes that lives close to Norco? I need to start ordering stuff to plumb the cooling and fuel systems
My issue is more the sizing, I just want tp make sure I buy the right junk the 1st time. At least Kartek is closeI always go to g&j for hoses and fittings. I also will use push lock stuff that I get from Kartek.
For the water stuff I ran -8 to everything and -10 for the dump. For fuel that’s all based on hp. You will probably be in the -10 range. I liked to go as big as I could from the tanks to the pump. Then -8 or -10 passes that. It’s been years since I was doing this but I can’t see it changing very much.My issue is more the sizing, I just want tp make sure I buy the right junk the 1st time. At least Kartek is close
It's not huge power, it pulled 650 @ 5200(if memory my serves me correctly) then the dyno started having issues so they shut it down... need to get all the plumbing, fuel pump, transfer switch(2 big saddle tanks) and then start wiring. I'm honestly just tired of seeing all that money sit in my back yard under the canopy rotting away :doh:For the water stuff I ran -8 to everything and -10 for the dump. For fuel that’s all based on hp. You will probably be in the -10 range. I liked to go as big as I could from the tanks to the pump. Then -8 or -10 passes that. It’s been years since I was doing this but I can’t see it changing very much.
Ohh was thinking he left off on lines and fittings. Either way, hate having to use shops for anything.Guessing interior work.
No, I have all the interior... needs plumbing and wiring, all of it. I'd like to do the work myself if I can get help figuring out what all I need to order. I'm out $3k of my parts budget and am hoping $2k of that will be refunded by PayPal for non delivery of work paid for.(Not counting on it, just hoping)Guessing interior work.
you're correct and I agree... I got hosedOhh was thinking he left off on lines and fittings. Either way, hate having to use shops for anything.
You can do it bro. For sure! I did my buggy myself and it worked out. You'll need to plan out all your lines and fittings on paper. I believe most of my fuel lines are -8 and -6 to fuel rail but I think for your application, you'll be good at -8 for all of it. That's a carb though huh? I'm sure you can get sizing charts at Holley or whoever manufactured the carb. I used summit for braided fuel line and fittings. I've read they aren't the best but have been good for several years now. I may just re-do all of mine over again to freshen them up. Good luck! You know us keyboard warriors got your backNo, I have all the interior... needs plumbing and wiring, all of it. I'd like to do the work myself if I can get help figuring out what all I need to order. I'm out $3k of my parts budget and am hoping $2k of that will be refunded by PayPal for non delivery of work paid for.(Not counting on it, just hoping)
1050 dominator carb, gonna go big on the fuel system so I can choke it down a bit till I have more $ to make more HPYou can do it bro. For sure! I did my buggy myself and it worked out. You'll need to plan out all your lines and fittings on paper. I believe most of my fuel lines are -8 and -6 to fuel rail but I think for your application, you'll be good at -8 for all of it. That's a carb though huh? I'm sure you can get sizing charts at Holley or whoever manufactured the carb. I used summit for braided fuel line and fittings. I've read they aren't the best but have been good for several years now. I may just re-do all of mine over again to freshen them up. Good luck! You know us keyboard warriors got your back![]()
