n4st
- Apr 23, 2023
- 3
- 7
:dude:At 90ft-lb with a 18t sprocket, the chains would react about 600lbs, or 300 lbs per chain. That's 5 times less than the working load of 1,540lb for the cheaper chain. Should be good to go with that one and save the cash. I had a feeling that would be the case but its fun knowing the capability.
 nce it goes back in there will just be one joint to weld in the truck. I am going to add one more bulkhead connector at the very front so there will be two in that area.
