- Thread starter
- #121
onanysunday
- May 6, 2021
- 3,941
- 3,553
I know. looks like I will miss a few trips.I would not do a thrash during dune season, unless it was on the sand car for some reason.
I will have to check that out. Good idea. All the parts in the emergency brake kit fit pretty nice. Now I just need to wire all of it which will be a project. The electric motor and servo for the emergency brake portion is pretty long so it has to be mounted low to clear when the suspension goes up. Rear tires are rubbing on the inner fender panels when the four link articulates. Need to figure out how much of a spacer and try bring the wheel out just a little bit. Wondering if a quarter inch will do it.Will the jack fit inside the rim?
Like 2nd gear in a 2D, it's a consumable. LOLHeader is close to the hood opening ram. Not sure if the heat will kill it or not. Making a heat shield will be a PITA and would be hard to make look good.
Sure hope not. Other issue is if it fails or there is a fire how to get the hood up. :scared: We have an idea for that.Like 2nd gear in a 2D, it's a consumable. LOL
