Kat-A-Tonic
- May 6, 2021
- 618
- 859
Looking so good. Keep up the good work!
I think I have chucked a screwdriver only once during this project. I actually have quite a bit of patience. Just had another big victory today. The Dakota digital dash has intermittently worked off and on the whole time. The tach water temp and oil pressure would not work if you reached up and pulled on the wiring harness. Finally got pissed today and tore the wiring harness all back apart. It ended up being the can bus plug way up high under the dash that wasn't getting full connection. It is a push on connector that normally would connect without a problem. I'm going to extend both sides of that and have that plug down lower under the steering column for access. And use a better plug.I gotta ask:
The level of patience and detail on this is amazing. How many tools were harmed during bouts of frustration? Any Looney Toons style tool-shaped holes in the walls? Random passers by hit by wrenches? Boots irreparably damaged after punting a trash can into Yuma?
:biggrin:
