Fullthrottleguy
Site Sponsor
- 1,485
Glad somebody chimed in with this about the tongue mount tool box. One of my neighbors has a good size toolbox on his desert trailer. Something like 60" x 18" x 18", not one of those trapezoid shaped tongue boxes but an actual rectangular below the bed rail mount truck box. I was definitely thinking of putting the 2k genny in there as well as the battery and maybe an air compressor. Maybe wheel chocks and some of the other bs like wheel chocks and whatnot.I had a similar experience - I was so happy thinking my tire was out of the way ... then ok Sh&t I needed it. Converted the well into a Camp chair holder ...
All the advice is solid -
I would add
nothing is better than Tongue mounted genny with a tool box on top - you move the battery outside into the tool box and put an air compressor in there as well, now everything that corrodes or makes fumes is outside all external connections and things you need are there and easy to get to and you are not crawling under a bench to check or change batteries and you can run solar wires outside if you want without making holes in the roof - which is never a win
A Max Air on each vent is always a good idea or swap the plastic tops for metal tops - you won't miss the light and you never have to worry about a crack or one flying off while driving
Depending on where you store, a window is really nice to have not just for light but if it opens its really nice if you are working in there
If you store somewhere your don't want people looking in a nice RV style velcro window cover works well - its just as easy to break in the trailer door as a window - so theft risk is low
I am huge fan of Fuel stations if you can afford it too
Good luck with the Fractal - Anthony and team build a nice trailer
square tools boxes you just have to be careful when you turn - some peoiple do an extended tongue for RV's and they work with big toolboxes.Glad somebody chimed in with this about the tongue mount tool box. One of my neighbors has a good size toolbox on his desert trailer. Something like 60" x 18" x 18", not one of those trapezoid shaped tongue boxes but an actual rectangular below the bed rail mount truck box. I was definitely thinking of putting the 2k genny in there as well as the battery and maybe an air compressor. Maybe wheel chocks and some of the other bs like wheel chocks and whatnot.
- I heard people aren't crazy about e-track on the floor mostly for mud/dirt type stuff due to clogging. Maybe not a big deal for the sand. I asked Fractal to put in 8 D-Rings. Hopefully enough to start. I like that they are flush mount so I don't have to trip over them. Planning to go with E-track on the walls with probably a set at waist height and another at chest or head high for mounting a couple cabinets or helmets, etc. I have a feeling I'm going to get carried away with the E-track.
-Not sure what vehicles are in my future. I'm thinking it'll be 3 quads and a rail at some point. Maybe there could be a kids RZR in there too, I dunno. Was planning to outfit a workbench up front that could maybe hinge up in case I get a dirt bike again and I could just E-Track it to the front wall. Probably just put a rolling toolbox strapped to the wall instead of permanent built in, just to keep it configurable.
- Spare tire in near the ramp up high seems like the right place for it. On the passenger side of the rail. I've definitely felt the anxiety of wondering if the spare will be enough to make it home, so two is a good idea for piece of mind.
-I guess I'll add that I store it at home in the side yard and security is not an issue. guess I should have ordered a window but too late now.
-Only other thing I'm thinking is I like epoxy floor + poly clear coat instead of rhino lining (heavy and gets hot in the sun) and before the coin flooring too as water always seems to get under that stuff and rots the floor before you can see it. I like the idea of sealing that wood floor as well as possible.
Thanks for all the great input, super helpful.
super nice - who's cabinets are those? Have not seen them before?
I believe they're from Pit Pal or Pit Products. Well made and light. Made for a trailer but the shipping is a killer.super nice - who's cabinets are those? Have not seen them before?
Definitely no "free shipping" back in 2018. Still kinda stings a bit.
these are the one's I am looking at for my new trailer - I had these 2 trailers ago - free shipping over $500I believe they're from Pit Pal or Pit Products. Well made and light. Made for a trailer but the shipping is a killer.
Very nice. I'll have to check out the winch box. I was just thinking about that this morning.these are the one's I am looking at for my new trailer - I had these 2 trailers ago - free shipping over $500
http://www.midwestracecabinets.com/store/p114/47''_Wall_Cabinet__13''_deep_16''_tall_47''_wide.html
we put their winch box in my friends toyhauler - it was so nice having it under the floor
I bought these cabinets and put them in a trailer a few years ago. They look good and do the job. The ones I got were also built very light and put together in a manner that left a lot of sharp edges. I would consider them again but would also look at alternatives.these are the one's I am looking at for my new trailer - I had these 2 trailers ago - free shipping over $500
I have been thinking about doing this. How does the tire clearance look, is it a big gap?Flip axels to avoid bottoming out - and in soft sections helps to keep you from getting stuck (becomes an anchor if the trailer drags in the sand)
This is a must for me. We have a couple little kids and go through showers. A buddy has this in his enclosed and always ends up giving us his water before he leaves. He has a 100 gal tank mounted over the axles, it’s a pretty sweet setup.Speaking of water tanks, on a fractal trailer build I watched I saw their water tank setup, it was pretty sweet. On the side of the trailer there was a typical door for the water fill but it was actually a water pump switch and hose bib. So when you wanted to transfer to the Moho you just hooked up your hose to the hose bib and hit the switch. Probably a common way to do it I just never seen it done before.
Buddy waterproofed a corner with a drain straight to the ground and uses a simple shower curtain for stag trips. Works pretty well.If you have a water tank installed on the trailer as a back up for the motorhome, put a sink in the trailer. The enclosed i purchased had a small bar type sink in it. I had never given a sink much thought. Now I wouldn't do another enclosed without one. Makes my life so much easier washing up after maintenance, CV issue, spilled fuel, etc and not tracking the mess into the motorhome..... happy wife happy life lol
Not the best comparison photo's - but here are some before and after...i haven't towed it yet with my motorhome - I did the flip a few months back.I have been thinking about doing this. How does the tire clearance look, is it a big gap?
How high did it lift yours? I want to do mine so I can get 16” wheels and better tires in there.Not the best comparison photo's - but here are some before and after...i haven't towed it yet with my motorhome - I did the flip a few months back.
I was worried it was going to look stupid, not that it matters, but still...It doesn't look that bad and I'm happy with it. I don't bottom out when leaving my street (back corner would drag) - and am hoping if I hit soft sand it will not be what drags me down.
I've been stuck once in my motorhome (Gordon's) - and the trailer was dragging - if it wasn't dragging it, I most likely would have made it through the soft patch as I was only 10ft from hard pack. Well worth the 200 bucks and time in my opinion...
One potential issue is if you double as a car hauler and tow lowered cars - cars will bottom out easier given the ramp is a bit steeper.
