Fullthrottleguy
Site Sponsor
- 1,487
Trailer is looking great - I have to say these guys are Fast!
Some have. But the rangers at G will still come over and write you a ticket.I realize the sink dumping to the ground issue is off topic but I gotta ask; if you can dump gray water to the ground as long as it doesn't go to a tank first then why doesn't everyone that takes an RV to G (or elsewhere) install a bypass dump valve so all their gray tank water can go to the ground? Not arguing, just asking.
I would guess the gray area here is "does it have one installed" not "is it being used". if it has one installed you have to use it.I realize the sink dumping to the ground issue is off topic but I gotta ask; if you can dump gray water to the ground as long as it doesn't go to a tank first then why doesn't everyone that takes an RV to G (or elsewhere) install a bypass dump valve so all their gray tank water can go to the ground? Not arguing, just asking.
I think if its just a sink for the occasional hand wash its not that big of a deal but if its for showering it would be a bigger mess. Tent campers have no grey tank and wash dishes in portable sinks and dump it on the ground.I realize the sink dumping to the ground issue is off topic but I gotta ask; if you can dump gray water to the ground as long as it doesn't go to a tank first then why doesn't everyone that takes an RV to G (or elsewhere) install a bypass dump valve so all their gray tank water can go to the ground? Not arguing, just asking.
In my situation, the trailer didn't have a grey tank. So, after the hassle with miss know it all, I just took one of the 3" caps for the RV drain gate that has a 3/4" male garden hose thread on it, a female garden hose to 3/4" pvc slip fitting, and extended some pipe back to drain between the axles.I realize the sink dumping to the ground issue is off topic but I gotta ask; if you can dump gray water to the ground as long as it doesn't go to a tank first then why doesn't everyone that takes an RV to G (or elsewhere) install a bypass dump valve so all their gray tank water can go to the ground? Not arguing, just asking.
how much is the ticket.Some have. But the rangers at G will still come over and write you a ticket.
Great looking stacker, cant wait to get mine started.
It used to be $25 or $50 for the first offense.how much is the ticket.
No idea. I just know that they aren't going to be interested in having a conversation with you about it. If you take the ticket and go to court your chances of winning are good. In Kraut's case I would've made it a point to find the ranger after the fact and let her know that she was wrong and justice had prevailed, but that's just me.how much is the ticket.
I’m sorry for the delay I’ve been in glamis all week.I like your duel fuel tank concept. Will it will be one pump and nozzle or two separate? Now you got me thinking about duel tanks for my upcoming build. I don't need racing fuel but thinking it might be nice to carry gas for the toys and then an extra diesel tank for the Moho. And if I went this route I could do a diesel gen in the the trailer instead of needing to be gas. Crap, thanks a lot, there goes another 15k or so
Are you worried about some a-hole seeing your sink dump on the ground and giving you grief? I like the sink concept but seems like more hassle than worth? I just use the waterless hand cleaner and paper towels then go in the moho for a final clean.
I would definitely go with a reel. I had a quick disconnect before and it was a pian. I would have fuel everywhere.A few updated exterior photos.
Exterior trim is all installed.
Looks like the fuel station is done as well. I can’t tell from the pics how it’s setup but it is done off a quick disconnect.
I had this on my last trailer as well and didn’t mind it. But I may modify it into a reel just inside the door. But I’ve got to get my cars loaded first to see if I have clearance.
Thank you, where did you put your reel? How many feet of hose?I would definitely go with a reel. I had a quick disconnect before and it was a pian. I would have fuel everywhere.
I think the hose is about 25' and I mounted on the ceiling driver side. I don't have a stacker so it was a bit easier.Thank you, where did you put your reel? How many feet of hose?
As mentioned I had a quick disconnect on my last trailer and didn’t mind it. But think the idea of a reel sounds good!
