Kraut_n_Rice
Site Sponsor
- May 9, 2021
- 3,277
- 2,595
No. We temp. source all our hydraulic stuff from the hot side. In theory, if you switch it from the cool side you can get a condition where the fan relay would cycle rapidly enough to arc weld the contacts together. And, you're only cooling a very small percentage of the fluid. On/off/on/off/on/off.... Switching on the hot side, it has to cool the whole system off before cycling out.You wire them into the cold side of the radiator, correct?
One truck we build requires 160+HP to drive a water pump (6gpm~ @40kpsi). Plus another 50ish for auxiliary functions. This is done hydraulically, and all the power is taken off the truck engine via PTOs. In this application we have to add a secondary oil cooler for the engine. It's probably 16x20x3". Holds 2 gallons of oil. This all happens while the truck is doing about 1mph @ 2200rpm. I'm firing up a fresh build tomorrow. So, it will have to do this continuously in 115* heat. We are taxing the hell out of the cooling systems....
