HydroPower
- May 10, 2021
- 95
- 53
Looking to upgrade the 16" electric radiator fans on my extreme sandcar, what are the best options out there for new fans??
Which series are you using on them? Brushless, high performance, extreme performance? I have heard alot of the new builds are coming with the brushlessI will only use Spal fans on any of my projects. Ive had great results with them, not a bad thing to say...
Bob
The cheaper one I'm going to try...If someone wanted to run/fab something like in the link Kevin posted, there are less expensive PWM standalone fan drivers. Obviously DIY. You don't need to run Holley or some other expensive controller.
https://www.autocoolguy.com/home
The site is kinda clumsy...but once you figure out how to navigate it, the stuff gets great reviews everywhere I've seen it. There are cheaper options available..
I'm in the process of working on a later model vette fan for my TJ. Tough to 'wheel in 115*+ heat and keep it cool at low engine RPM...
I was thinking about running one of the delta pag, but they show you can run it with typical wiring, it would just go to full speed, i dont really want the variable speed for the sand car,If someone wanted to run/fab something like in the link Kevin posted, there are less expensive PWM standalone fan drivers. Obviously DIY. You don't need to run Holley or some other expensive controller.
I've only read a tiny bit about the delta pag units, but some PWM fans will go 100% if you put the signal wire straight to power/ground.I was thinking about running one of the delta pag, but they show you can run it with typical wiring, it would just go to full speed, i dont really want the variable speed for the sand car,
Negating the need for a relay as well, I assumeI've only read a tiny bit about the delta pag units, but some PWM fans will go 100% if you put the signal wire straight to power/ground.
Correct. Direct to the battery with circuit protection.Negating the need for a relay as well, I assume
We run a brushless Spal fan on a hydraulic heat exchanger in one of the machines we build. The Yazaki power connector is special and kinda spendy and so are the sensors. Spal does make them in different temp ranges than the ones typically advertised. For instance, the one we use starts at 120* and is full on at 160*.Kartek has a diagram for a very simple setup for the SPAL fans:
https://www.kartek.com/parts/spal-30107101-plus-series-16-curved-blade-brushless-puller-fan-drop-in-mount-sits-inside-shroud.html
You can run up to 12 fans off of one sensor. Pricey, but fuss-free. Just wire together and ship it.
You wire them into the cold side of the radiator, correct?Correct. Direct to the battery with circuit protection.
