Reece Pettersen
- May 6, 2021
- 326
- 426
I want to build an interest list for an idea I have been brewing up for awhile.
As many of you know, I am a die hard Alumicraft racer/duner. I have had the opportunity to own and drive many different cars (600 hp Mazzone, 87hp 1600 car, 850hp class 1) and found the most fun I could have in the dunes is with a car that is balanced, light weight, gets out of the hole, and can handle some whoops. I am playing with the idea of spec'ing a light weight car from Alumicraft and want to see if anyone else would be interested. I included some basic info below, but the idea is to create the ultimate pocket rocket for $100k.
Chassis: Alumicraft pro buggy, widened to a 2 seater, mid engine, extended trailing arms
Trans: Weddle S5
Shocks: Fox 2.5 IBP Front, 2.0 rear coil & 2.5 rear bypass
Hubs: Proam 2" hollow front & 934 Midboard Microstub Kit
Engine: 350-400HP N/A 4 Piston Racing K24 Endurance Racing Engine (Can go to 500-750hp turbo, but will put budget over $100k)
Electronics: Holly ECU & basic wiring
Please reply if this is something you would be interested in. Please don't comment on this post if you aren't serious about building a new car or if you are a Buckshot fan; you aren't welcome here.
Trans: Weddle S5
