JM PRO
- 259
Hi team,
I've read all the other threads we have on this site and appreciate everyone's input. The current project I am working on is a 383 stroker, with Eaton M112 supercharger at 8 pounds of boost. Car will be running E85.
I've got 2 options I have at this stage of the game.
(Option 1)
Buy the Mishimoto heat exchanger that is 26" long x 7" high and 2.25 thick. Add 3 8" fans to it. It will be located behind the crdboard gas tank and below the mid rail. There will be a panel covering the gas tank and mid rail. This location will get very little air flow so fans have to do most the work.
(Option 2)
I have a new cherokee radiator that I bought for a project and never used. It measures 35 x 11.5 x 2.5. Has 3 10" fans. As you can see in the pics, it will be roughly 50% above mid rail and get much better air flow.
My question boils down to how much do we need to keep that intake charge cool. Will option 1 with the hidden, cleaner packaging work totally fine or option 2 is the must. I can also raise the Mishimoto heat exchanger up above mid rail as well for more air.
I am all ears.
(Option 1)
(Option 2)
I am all ears.
