Another J35 Swap
Did you order it from Kennedy? Check with weddle or pacific customs. They might have them in stock.
I ordered through Moore Parts. I called both pacific customs and Kennedy and they said it was 4-6 weeks but I didn’t try weddle. Moore had free shipping and $30 off
Flipped intake doesn’t really work for me :/ I’m okay cutting tubes and adding new as my dad has a tubing bender but I was hoping to avoid it
May give you the clearance you need to clear the rear hoop.
How much spacer is too much spacer?😬 I assume I shouldn’t go higher than the factory spacer already is. If I can though I’d strongly consider it
Well, I guess a longer runner would translate to more top end in theory... The short 3/4" runner is for torque. I'm just speculating since that is true with most domestic platforms. I have not tried to stack them myself.
Now I'm going to have to go down that youtube wormhole LOL!
Opposite: longer runners enable dynamic supercharging at lower rpm since the pulses are farther apart.
Gonna love the power difference.The torque is going to be the best part easier to drive.I went from 2275 to a j35.
So with all that above said, adding the 3/4" spacer to the existing seems to be the intended use from P2R. A quick call to them would clarify that I'm sure.
Finally got my adapter plate in and got everything mounted up today! Didn’t get water lines plumbed but fired the engine up and it sounded good! Going to do a 2-1 1 3/4 tubing to single 2.5” muffler in hopes to get rid of the burble v6’s with duals seem to have. Super excited to give this thing a go!IMG_9853.jpeg
It’s together and runs! Complete with exhaust and working radiator fans😎 the only problem it’s having is that it has a limiter at 4500rpm for some reason. Guessing it’s thinking it’s in park/neutral, if anyone knows a workaround or a different factory ECU I could swap from a manual maybe I’m leaving in 7 days for the sand and would love to have full rpms!IMG_9869.jpeg
Here’s the only clip I got of me racing this weekend! The buggy did excellent and was the fastest out of our group! (A few 3800’s, some VW’s, an ecotec and a Outfront turbo Subaru) definitely glad I decided to go with the Honda swap. The first two days I ran on with the 4500rpm limit and it was nuts. Then I swapped in an ECU from a 2000 odyssey with the pins jumped it so it would engage vtec and it absolutely became insane. 4th gear broke (I think) during a full speed pass! It made a nice drain hole for all my oil :/
