Another J35 Swap
Did you order it from Kennedy? Check with weddle or pacific customs. They might have them in stock.
I ordered through Moore Parts. I called both pacific customs and Kennedy and they said it was 4-6 weeks but I didn’t try weddle. Moore had free shipping and $30 off
Flipped intake doesn’t really work for me :/ I’m okay cutting tubes and adding new as my dad has a tubing bender but I was hoping to avoid it
May give you the clearance you need to clear the rear hoop.
How much spacer is too much spacer?😬 I assume I shouldn’t go higher than the factory spacer already is. If I can though I’d strongly consider it
Well, I guess a longer runner would translate to more top end in theory... The short 3/4" runner is for torque. I'm just speculating since that is true with most domestic platforms. I have not tried to stack them myself.
Now I'm going to have to go down that youtube wormhole LOL!
Opposite: longer runners enable dynamic supercharging at lower rpm since the pulses are farther apart.
So with all that above said, adding the 3/4" spacer to the existing seems to be the intended use from P2R. A quick call to them would clarify that I'm sure.
