Funco4JM
- 151
This summer I decided to swap my Turbo Honda for an LS1. The engine came out of a running sand car before it was pulled out. I have two thoughts and I am looking for direction before I start to replace a bunch of stuff. After filling the radiator and expansion tank, I fired up the engine and let it warm up. The needle on the gauge hovers just under 210* at idle sitting in the garage with an ambient temp of 100*-105*. If I let it sit for 15-20 minutes, the gauge temp will slowly start to increase, and the engine will get hot (it goes to the line between 210 and 250) and then I shut it down. If I take it out on the road, the engine starts to get hot even while cruising at 2000 rpm in 4th gear, same issue. Don't want to overheat it so I shut it down. (I did fill the radiator all the way and forced coolant into the expansion tank to be sure / I also burped the heads numerous times to be sure it wasn't a steam issue).
1 - My radiator in the car is a CBR 31x19 with dual 14" fans. It is about 16 years old as it seems to be original to the car. With the swap, I had the inlet/outlet fittings moved from one side of the radiator to the other side of the radiator. Two questions... First, does moving the inlet/outlet from one side to the other pose any cooling problems with the radiator? Second, do radiators go bad?! The fans work fine and come on one at a time at preset temps from the computer.
2 - My cooling lines are hard lined 1.5" and 1.25". Is it possible with them being near the headers that they are heat soaking that fast?
With as late in the summer as we are and only a month to get this figured out, my options are to replace the radiator completely, replace the cooling lines with -20AN soft lines, or replace both. If I do both its going to be another 2K.
Help!!!!
Help!!!!
