dbart
- 4,356
:threadsucks:Making it sound like you’re jealous the pool gets more sucking action…
2 wheels...Anyone know what the difference is on the Pool Cleaner 2 wheel vs 4 wheel?
We actually inherited this 4 wheel Pool Cleaner with our house....not sure how old it is.
Very nice cable but you don’t know if it gets changed to 12: or 24 volt. I’ll check out the main box. It might say output voltage. Ran it another 6 hours today and got this and my pool is super clean but it’s finding more stuffStill crazy to think about putting a 120v electric corded cleaner in a pool.
i like that, probably going to get one of those. my pol floor looks cleaner and a lighter color then i remember. this has way more suction then the normal pool cleaner so i do believe it is pulling up stuff the other one just cant. and it scrubs right up to the top of the water line on every wallI really want to be as Sham-WOW as the next guy.....but all the finer material yore seeing gets sucked and filtered at the main DE Pool Filter. Your simply catching it an early point that can be cleaned each time you pull out the robot :robot:
Do you at this time feel the water is truly clearer, less items floating around?
I'll say that unit scrubs better, or it should...
Big debris and leaves were never a big problem as I have a leaf canister for that stuff.
i run my pool pump the same as before, i didnt buy it to reduce that or energy savings. i have some blackish stains on the lower side walls for years. maybe i dont scrub down there hard enough, was hoping it would work on that--time will tellThe rocker electric pool sweep is a cool idea BUT wouldn't you still want to have a certain amount of water changes through your DE, sand or particulate filter anyway? So you would still have to run your pool pump everyday in turn not saving you any energy.
i have always had a DE filter and water was always OK, had the same filters for last 10 years but think they were getting larger unseen holes or tears so i changed them to the pure and clear filters--no more DE and i instantly saw super clean water. so now not wanting to clean "those" filters as often i decided to get this unit and plan to run it one a week after i get the pool all stabilized from the changesYeah, I get the scrub part. We hit it with the brush once a week with the current setup. It's only when the planets fully align and the DE Filter gets cleaned that our pump vacuum unit can even climb the walls....and not effectively either.
I can't imagine this Elec Robot unit draws much, another factor to consider is electricity bill using it.
yes but now it scrubs everything@Crusty I think that was Johns goal was to "SCRUB" the bottom.
@John@Outfront do you still run the normal filter to get water born and top sludge debris?
