- Thread starter
- #41
Big_Daddy_Jp
- 1,260
Just the kind of info I needed to hear! Thank youNice! Good for you. You will learn a lot about your jeep the longer you own it. Just a tip, when you find an issue with it, google the problem. It is covered with a good tech write up on it somewhere amongst the inter webs.
Be careful increasing the lift without an engineered kit. Bad things happen with lower control arm angles getting steep and driveshafts angles getting extreme. It’s not uncommon to throw a u-joint and have your driveshaft reshape your floor. You can start cutting the wheel wells and getting wild with the sawzall, but making openings big enough for a big tire is mostly feudal. Stick with 33’s and go up to about 4.5 with long arms. You’ll be much happier. My last ZJ had a 4.5 RE long arm kit on it with 33x10.5 tires and would go just about everywhere with minimal rubbing and stock wheel wells (trimmed bumper corners).
