wesinls
- May 6, 2021
- 982
- 1,245
This feller?The ones in the back of the head do nothing, All the new motors do not even have the provisions for the head gaskets,
The way the block are machined the pumps sits lower than the tallest part of the motor, so in that small pocket air can be trapped, then big enough pocket it can add some cavitation
We also make a full kit, Made in America by a board member that has a Haas,
Best thing would be to periodically bleed them or get a kit to add them back. Any air bubbles from localized boiling in the heads will be trapped there. Head cooling is important for detonation.Mine are blocked.
Came back from engine builder like that after rebuild.
Same car, same problem, same solution, are you my friend??My friends Funco has what you show in the pic. Just a crossover tube with no breather to the expansion tank. Several times we had to stop due to an overheated head issue. Both times we had to crack the crossover tube bolt and let it breath out the steam. It was messy and a PITA. I have the stock style crossover with a steam tube that goes to the expansion tank on my LS swap I am doing.
No big deal, just might have a hot spot in the cylinder, GM spent a lot of time and money on this design, so i would not take it lightlySame car, same problem, same solution, are you my friend??
After "burping" 2-3 times the overheating problem was gone. No big deal.
Correct Designed by KRC, we use a cross over and a T, will post a pic, we run them back into the water pump on the return side,This feller?
https://www.alpermotorsports.com/index.php?l=product_detail&p=169
Suction is sufficient there to pull the bubbles I take it? Was planning on running mine back to the radiator (already a fitting there).Correct Designed by KRC, we use a cross over and a T, will post a pic, we run them back into the water pump on the return side,
Ty, just purchased a set!Correct Designed by KRC, we use a cross over and a T, will post a pic, we run them back into the water pump on the return side,
Yep. Under no circumstances should the steam port go to a catch can. Pressurized side of the system only, otherwise you'll have a bit of a mess on your hands... :biggrin:one other comment to throw on top of @Rockwood's comments..........
there is a very distinct difference between a "catch can" and a "surge tank".
