- Thread starter
- #21
onanysunday
- May 7, 2021
- 3,724
- 3,435
So my diesel guy had this cool guy plug. Custom 70 pin connector to plug into the motorhome side of the ECM. We knew there was an issue with something in that plug. Had a hell of a time and still never found a pinout for it. Found an old thread on the RV forums showing me the two constant hot leads and then the switched power lead. Those checked good. Took a guess on where the ground was going in and found this single wire going into two wires. One of the two wires was not showing any connection after this junction. Ran a new ground wire directly from the battery to this junction and it starts and runs finally again. Need to throw that beast of a drive shaft back in and go drive it.But pretty sure this is the issue. A couple of codes that came up with the scanner but I'm hearing it is drivable.
