Jtmoney714
- May 6, 2021
- 912
- 798
For mountain trails I find the 5w radios useless. If you aren’t in line of sight they don’t seem to work. I do use them for backing the motorhome into the yard.
I agree, in the mountains they're not as good. If you're in the same valley it seems like you can get a couple miles, but if there is a geographic feature between you (like one of you comes around the end of a ridgeline and now the ridge is between you) they don't do much. The antenna setup I just posted helps, but it's still not amazing. I'm not sure how different the 15W version I just posted will be, TBH. Even the 40W I think is always going to struggle if you have a ridge between the radios.For mountain trails I find the 5w radios useless. If you aren’t in line of sight they don’t seem to work. I do use them for backing the motorhome into the yard.
