tjZ06
- Jun 9, 2021
- 968
- 1,148
I bought this truck new in October of 2010, and I've always thought about doing a Solid Axle Swap (SAS) on it. For years it towed my 5'ers, so going big and SAS didn't make sense, and it wasn't in the budget anyway. Ever since we moved over to RVs though, it's mostly just been a weekend driver, or used to move bumper-pull trailers around. Recently I decided to use it as my "Overlanding" rig, and installed a Fourwheel Campers Hawk pop-up in it:
Now, I debated a lot about buying a new rig for this job. I was considering new RAM Power Wagons, or maybe a new Ford F250 Tremor with the 7.3 "Godzilla" gasser. Both would be great for the job, and have the advantage of starting solid axle. I love the new RAM interior too. At the end of the day though, I have my truck, kit's been paid for for ages, and it was mostly just sitting. Also, being diesel and deleted, and having a 60 gallon fuel tank in it (replacing the stock tank, obviously an in-bed wouldn't be an option w/ the FWC) it gives me range the gassers just wouldn't. There's also something to be said for not taking a brand new truck out wheeling and getting it trail-striped up - not that I'm not going to cry like a little girl as I get more chips and stripes on this one.
As for what's in the truck now, it's a been a slow evolution, if you will, but it's nicely modded:
So, what are the plans?
Some other things I'll have WFO (or somebody else) look into seeing if they can build will be:
And other things I ordered to go with this setup:
Here's a quick vid that gives a run-down on WFO's SAS, and also goes over the options they have to deal with the GM 8x180mm bolt pattern as well as ABS tone rings. The vid is old, so if you go with a solution that moves you to 8x170mm (such as the Free-Spin kit I'm doing) then they just re-drill the rear axles, vs. going with adapters:
And finally, a couple questions for y'all:
-TJ
- 60 gallon stock-replacement fuel tank (honestly, I forget if it's a Titan or TransferFlo - a buddy of mine had a '11 that was a SEMA truck for a few years, one year he was sponsored by one brand, the next year the other so I got the tank cheap when he swapped)
- FASS Titanium Lift Pump w/ Dual Filtration/Water Separator
- BANKS CAI
- Catless "5 inch" Downpipe (the quotes are there because it's not 5" right off the turbo, there's simply no way a true 5" would fit between the turbo and firewall)
- Full 5" Exhaust (w/ Muffler)
- Cognito ~5" Lift
- Method HD wheels w/ 35x12.5-18 Toyo Open Country M/Ts
- Custom Tuning
- H&S Black Maxx (used just for gauges at this point) on custom A-pillar
- Black Alcantara Headliner and accent panels (very clean, subtle and not Gucci
- Full custom system with 2 10"s and all Hertz components, subs and amps along w/ a Alpine 8" HU that included a new trim panel to fit with a stock appearance
- Amp Steps
- Some finned rear diff cover (I forget the brand, took me a while to find a nice one with no branding)
- Lots of rock chips thanks to thousands of miles off-pavement in Idaho and CA, and lots of Glamis recoveries with all 4 tires blazing
- WFO Solid Axle Swap set around 6" of total lift
- Fox Coilovers (front, staying leaf rear with Fox remote resis)
- Dana 60 w/ 4.88s, ARB Locker
- Rear re-gear to 4.88s, ARB Locker
- New Rear Spring Pack (to match height, all lift in spring pack, no blocks - probably not going with the Deaver pack since I'll have the weight of the FWC we'll do a custom pack)
- Free-Spin kit on D60
- New wheels (probably stay w/ the same model of the Methods, but move "down" to a 17" wheel)
- 37x12.5-17" Toyo Open Country M/Ts (might go 13.5" width, haven't decided)
- WFO T-case Clocking Kit
- Custom Driveshafts
- Skid for the giant fuel tank
- Skid/protection for the FASS and filters (it's already tucked pretty damn high on the frame rail, I need to get under there but IIRC the filters barely hang below the frame rail, still I'd like 'em more protected)
- Hidden Winch Mount (I kinda hate all the bumper options for these trucks)
- RIGd Ultraswing Mega-Fit Tire Carrier (w/ Table and "SideHack")
- Do you know of a CLEAN looking '11-14 D'max front bumper with winch mounting? I hate the giant chin under-bite look of most of 'em
- Wrap the camper to match the truck better (either silver, or maybe a charcoal gray), or wrap the truck to match the camper (IDK if I could go all-khaki, but maybe a "flip" of the camper colors with mostly black with a khaki stripe?)?
-TJ
