Dockmaster
- 1,086
Getting ready to do my first oil change on my 2D with Deco case. What tips or tricks do I need to know? I read somewhere the capacity is 4 qts. Is that correct? I ordered 2 gals of Maxima 75w-190 from Weddle to make sure I had enough and then extra. I assume you just fill it until oil level reaches the plug level on the side? I’ll use a clean drain pan and inspect the old oil for any trouble signs. I don’t know what oil is in it now so I’ll drain as much out as possible. Anything else?
