wesinls
- 1,289
Anyone using one of these batteries on their LS? Per some Google searched people are using them in their street rods...
The previous owner of the car used a fork lift battery which is somewhat hard to find - and has a custom aluminum enclosure for it...clean setup...the same enclosure has the fuel pumps, filter, shutoff, etc. all mounted to it. I'm trying to find a more available battery that will fit in the current space. PS950 will prob work, but it a bit longer than I'd like...the PC680 would be perfect, just not ideal from a cranking amps perspective, although a lot of people seem to be using them in street cars.Curious...what are you trying to do?
A gp24 lead acid battery works just fine.
Your rail weighs a ton doesnt it?
My brother had that same battery in ls power car worked great when engine cool once warmed struggle you start. Changed to a 925 no issues in it at all.Total power 1200 is about 2” wider than a PC 680. Might be a good choice if it will fit. https://www.kartek.com/parts/group-u1-total-power-1200-series-battery-measures-7-12-wide-5-deep-6-34-tall-8mm-battery-post.html
