SeanRitchie
- May 6, 2021
- 421
- 984
That's bad enough to pull it. Could be bearing, could be worn gears. If you need gears, sorry to say you might be waiting awhile unless you can work with a different ratio we might have in stock. If you need a R&P, please don't call and yell at me, I get enough of that already. Just going to have to be patient and maybe we can get you something before the end of the year.I got a Mendeola S4 that during last season started making noise. When I'd start it, it sound fine. After I put it in gear, move it and put it into neutral and let out the clutch you could very clearly hear the tyranny spinning over the loud running V8. I also notice now I can hear it if I just start it in neutral but not as loud.. So I go to drain the oil and the drain plug is full metal.
At the start of last season the magnet was clean and got fresh oil.
This is what I was able to clean off and let sit over night on a paper towel.
The piles are not flat. I'm guessing I have a bearing going out, input shaft, main shaft? What do you think @Sean@Weddle ?
Jokes on you, By the time my 2 year old is ready for college, it will be free!Sean says thank you! It looks like his kids are going to Harvard after all.
How many of those 18 speed gearboxes are produced compared to ours? I would bet 50,000 (or more) to 1.great story..... i have a 18 speed in one of the petes the low side of the splitter has a bad gear loud nock if you put in low been like that for two year and about 200k miles so its a 9 speed now. well ist about 4500 for a rebuilt 18 speed i just cant understand the pricing for these gearboxes
Big volume production goes a long way to bring down cost of parts. I won't get into the variations of material qualities and required duty cycles.
