- Thread starter
- #181
Rockwood
- 8,713
Naw. There’s nothing behind it I want air hitting, and adding air behind the radiator reduces cooling capacityGonna cut the vents out?
Lol. Didn’t you see my heat shielding? These clogs are coooooooolNaca ducts. Tubes down passed the headers to cool them more. Keep those tootsies cool. Guessing you have the "high" performance jobbies though...
where did you purchase that exhaust wrap material looks good i need some to wrap a water line right above my turbo on my 2013 duramaxView attachment 186842
Final product. There is a VERY noticeable difference in temps of objects near the exhaust where there is wrapping and not. Put your hand on the “frame” next to the wrapped exhaust, cool to the touch. Next to unwrapped exhaust, barely bearable to touch.
So you can not wrap a heater hose with it? You’re saying it will melt my hose ?
If you wrap anything melty with it, make sure to leave air gap. The shielding itself blocks heat from passing through, but it definitely absorbs it. Anything in direct contact with it will fry.
I would place it between the hose and the source, or wrap the exhaust partially. The heater hose doesn’t need to be wrapped to be protected, just blocked from direct radiated heat.So you can not wrap a heater hose with it? You’re saying it will melt my hose ?
