NEW STYLE SEQUENTIAL SHIFTERS
J Alper
Site Sponsor
Finally got the HAAS up and going,
We are making our own shifters now,
All in house
Bigger Bearings,
Better geometry for the cables
The levers also sit on the same shaft,
so you can move the reverse to the other side if that is preferred,
Also can do custom design
Also we will post our All Black
is there a "return to center" on the main shifter or is it just the handle in the mount?
Then if you are Looping The cables on a PBS, we also make a lever to change the direction of the cable throw, no more fabricating sift arms,
We have is setup with spring if you want a Spring option, some trans make a spring shift funny some it helps, so we do both
Now inhouse I can pretty much make anything,
I want the one first pictured. Looks killer. I hate my extreme pistol grip one. Anyone want the extreme one?
Awsome, will hook you up,
I also have a couple more style coming, just differenc Knob options
would these be a direct bolt in replacement for a harget shifter? Hole locations and width?
It can be, if you let me know the center to center on the Hargett we can punch holes in the bottom to add the same bolt pattern and the width of the shifter to add spacers,
Also we can flip the Handles around if you like reverse closer to you,
Hargett is a 4.125 Center to Center Bolt Pattern
We make our own plates, so we can make the same bolt pattern pretty easy.
Those are BEAUTIFUL !!!!!
Thank you as always, your car has always been my favorite to work on, good times back then
Should have the new Reverse Levers done in a couple of hours
