J Alper
Site Sponsor
- Apr 30, 2021
- 2,134
- 1,848
We have is setup with spring if you want a Spring option, some trans make a spring shift funny some it helps, so we do bothis there a "return to center" on the main shifter or is it just the handle in the mount?
Yes i can do a skinny shifter with no reverse handle and add the Albin Knob with electric reverseAlbins option?
Yes we can do a Single Lever with No Reverse HandleAlbins option?
Awsome, will hook you up,I want the one first pictured. Looks killer. I hate my extreme pistol grip one. Anyone want the extreme one?
would these be a direct bolt in replacement for a harget shifter? Hole locations and width?
It can be, if you let me know the center to center on the Hargett we can punch holes in the bottom to add the same bolt pattern and the width of the shifter to add spacers,would these be a direct bolt in replacement for a harget shifter? Hole locations and width?
Thank you as always, your car has always been my favorite to work on, good times back thenThose are BEAUTIFUL !!!!!
