Sutton
- Nov 18, 2025
- 111
- 105
Would you ever consider the 10.75 fronts? I'm curious how they would do on a car this size.
They match up well with the 33 blasters. Definitely would want a good spindle.Would you ever consider the 10.75 fronts? I'm curious how they would do on a car this size.
Yea, they look and work great. But I snapped a combo spindle with 10.75s. So I would hesitate to go to that size. To each there own. Plenty of guys running a 10.75 with combosWould you ever consider the 10.75 fronts? I'm curious how they would do on a car this size.
You can run 10.75 with combos if you drive like a B*tch.Yea, they look and work great. But I snapped a combo spindle with 10.75s. So I would hesitate to go to that size. To each there own. Plenty of guys running a 10.75 with combos
Here’s a couple I’ve done for Sandcars.Any pics of shaved 10.75 ?
This is a great looking car. Do buffed tires not push really bad in corners? Tons of guys swear by them, but I can’t wrap my head around the physics.I had a set of Mickey Thompson 33" Baja Pro fronts buffed to smooth, which I absolutely love. The rear tires are the STU Sand Blaster 33 pro, also great. It's a Chenowth Explorer frame, the motor is stock J35A and the trans is a Mendeola 2D. Hope it helps. Cheers!View attachment 176643
That is more dependent on the car.This is a great looking car. Do buffed tires not push really bad in corners? Tons of guys swear by them, but I can’t wrap my head around the physics.
Thanks! Admittedly, it was more about convenience (I had four MT Baja Pro fronts) and looks. I think HP Habits makes good points about weight and about type of car. For my duning style and on my car, they're perfect. I had them buffed at Rogue, they were awesome to work with, and now I believe they are making/selling their own version.This is a great looking car. Do buffed tires not push really bad in corners? Tons of guys swear by them, but I can’t wrap my head around the physics.
