I run summit's 8708 Cam in my LS1/6
That is a Huge cam for a stock LS6 for bottom end ^^^
One issue you will have with a stock cam is Lift, .600 lift on a over rev with a good lifter will bend the valve,
Most get away with a .600 lift due to Crap Lifters, a super quiet lifter will loose a lot of lift under spring pressure,
Need some spring pressure so you don't bend a valve,
To do this correctly you need to use a good Lifter, a performance race lifter like a Johnson short travel will get you all the lift, and the correct degree on the cam ,
A soft lifter will get you something, but not what the cam spec are,
Start with good lifters if you are doing a cam swap, if you really want to make a difference,
If you have good lifters then i would max the lift at .585 on the lift, Crap lifters you can go to .600
If you want a torque cam then it will not accelerate hard it will just pull smooth and steady,
with a Lobe Sep around 116-117
But if you get to a 111-112, it will come in more around 2500 rpm and rap hard, but will have zero power below that rpm, but will make great power, and keep it a plus 3 or plus 4,
If you want I can get you a great price on a Cam Motion cam, custom or off the shelf,
your LSA depends on your driving style,
