New ride for the dune season - Kawi H2
Another great trip to Glamis in the books and another 300 miles on the H2. We did a ride to Duners Diner yesterday morning from Wash 15. Headed from the Wash to China Wall then to Disco Ball and then off to the diner. It was about 52 miles round trip and the H2 took about 9 gallons to do it. It was a gas hog on the way back. Gas gauge was just about 3/4 when we got to the diner and the gas light was flashing when I got back to camp. With the gas light flashing there is still 5 or so gallons left in the tank.
Only issue this trip was killing a belt. Probably going to just run with the clutch cover off. I ended up putting on a new stock belt as I do want to see if I can get one to live. Car ran great and I smoked my buddy up Olds in his Pro R two seater with the 300hp Bikeman set up.
Another great trip to Glamis in the books and another 300 miles on the H2. We did a ride to Duners Diner yesterday morning from Wash 15. Head from the Wash to China Wall then to Disco Ball and then off to the diner. It was about 52 miles round trip and the H2 took about 9 gallons to do it. It was a gas hog on the way back. Gas gauge was just about 3/4 when we got to the diner and the gas light was flashing when I got back to camp. With the gas light flashing there is still 5 or so gallons left in the tank.
When you broke another belt how did the new clutch cover hold up? Are thinking of running without the cover as you think the belt is getting too hot? Or just for easier access? Definitely not the easiest cover to get off and out of the way. The belt you blew was that the GBoost or a stock Kawi belt?
I’ve read other say the fuel light starts flashing with about 5gal left, so 1/3 of a tank. Seems too soon to me. I could see with 2 gal left.
After seeing Chupacabras reel I’d stay away from Aftermarket Assassins H2 stuff right now. Muffler cracked at the pipe, and compared to the other’s exhaust it did not look like as good. And Chupa thinks the AA tune is wrong too and was not happy with customer support.
It was a OEM belt that blew and I was running the cover that already had a hole in it. I will run the good cover when I go to the desert. Two reason for no cover - 1) much easier to change a belt and 2) I think the secondary gets too hot when getting after it on a dune run.
For the life of me I do not understand why Kawi did not put any cooling fins on the secondary to help move the hot air out the duct and help dissipate the heat.. The clutch gets plenty of air flow as the primary is not nearly as hot as the secondary. Also think the stock belt needs to be about 1/8th longer and that would help with the heat as well.
When I was cruising on the sand highway to duners diner (speed were 50-70mph) the clutches were warm, but not hot and the belt was warm. The load on the car is much less and RPMs were in the low to up 7000 range. Now when we were ripping around the dunes the load is much greater and the secondary was hot even with the clutch cover off. You could put your hand on it and hold it there but it was definitely hotter.
I know the Gboost belt runs cooler from my last trip, but you do loose some top end. I am waiting for Evo to release the Alpha belt for the H2.
These are dune issue with a person that is not going to go easy. Both trips the sand was wet which makes things worse. I would love to get a trip in the dunes with some dry sand and see if I have issues. I do believe in the desert the belt will not be an issue as you do not put as much of a load on the belt.
Bummer for Nick and the AA tune. He said when he first put the tune the car was moving and very responsive.
I am in no rush to get a tune on the car. The KWI weights really wake up the car and almost feels like you put a new tune in the car.
Suspension wise I think the front shock valving and bypass porting makes for it being too soft. It will blow through the compression way to easy in "firm setting".
I wondered the same thing about no fins on the secondary. I was a bit surprised to see no air inlet on the secondary either. You would think they would have made it easier to get the cover off around the shock. I bet that was low on the priority list and not doable with the suspension design.
I wonder who is making the belt for EVO. I’d like to see Hunter Works dive in and get a belt for the H2. What’s nice is he does not hide who he works with manufacturing his belts.
I too have never been a fan of tunes. I don’t mind it when they just unlock Nannie’s like speed limiters, but when they start playing around with boost, timing etc. that’s not for me. I’d take reliability and focus on suspension to make up for the benefits more HP might get you.
As far as the front shocks. Schmidty and I can’t remember the other shock tuner I was talking with at the Sand Show. They both said they felt front shocks only needed a revalue and better springs. The bypass holes in the can were fine. But in the rear they both said the rear bypass holes were not in the right locations and they would make new cans for the rear.
The Secondary does have an air duct to it that hits if from behind. The clutch cover is easy to remove as long as you are on somewhat level ground. If the clutch side is on the downhill side it moves the shock in a little closer making it a really tight squeeze to get it out. I suspect Kawi is going to make some changes/updates to the clutch ducting and secondary design.
Gboost makes the belts for EVO.
Suspension wise the rear suspension for the dunes is good. I have not bottomed out the rear suspension or smacked the rear skid plate. The front is what scoops the sand. I saw the other day that SDG is doing suspension work on the H2.
Mess free oil change. Did not even need to drop the skid plate. Kawi has a plastic skid under the engine and it can easily be removed. Can Am engineers should take notes. The sight glass is super handy and the oil filter is an easy access location. Trying Motul synthetic oil as they sell it in a handy gallon jug. Car takes 4.47L of oil. I was going to do the transmission and front diff, but did not have the right socket to remove the fill bolts (27mm). I will do that before my next trip, MLK weekend.
Is 10-40W what Kawasaki specs? What about changing the oil filter? I assumed that might be the messy part. Where does the oil filter oil drain on to?
The trans & diff fill take a 27mm socket? Thats big! How much oil does each of those take? What weights and anything special?
Kawi specs call for 10-40w. Oil filter I put paper towels underneath to soak up any oil that comes out with the filter.
The 27mm socket is to get the fill hole bolt out. I have not changed the trans and front diff yet. Front diff and trans take 90w gear oil. I am at a race for my kid and won't get to it until next week.
I'm about to embark on the X3's oil change... Argh.
How nice of them... 🤣 .
The ONLY thing I disliked about my Polaris XP4 900 was the oil changes. What a PITA! That low IQ "Drip Tray" they include/use for the filter was BS, as was the rest of the job. Glad to see it's a lot easier on the Kawi.
Another 170 miles on the H2 and another 2 belts said no mas! It did not matter if I ran with the cover or no cover that secondary on the H2 gets stupid hot if you are on spirited dune runs and is killing belt life. Set a personal record of killing a belt in under 40 miles. Frustrating for sure. That is 4 belts in about 770 miles.
I talked to a few different H2 owners in Glamis this weekend. One guy smoked way more belts then me and another guy had 1200 miles on his current belt. The second guy was not a dune only person and had lots of baja miles on his car. That gave me hope out in the desert the belts will survive. He did make a scoop to force more air into the clutch ducting.
Kawi needs to come up with a new design for the secondary and find a way to force air on it to keep it cooler. I think it is a combo of belt slippage and lack of sufficient airflow causing the issue. The primary is considerably cooler.
I did take the secondary off to inspect it and clean it. Learned the secondary bolt is left hand thread. Nothing like messing was a bolt to have the camp engineer come over and say the big "L" on the bolt is for left hand thread. LOL! Cleaned up the secondary and cleaned up the grease that Kawi had inside the helix. I guess they use some grease to get some pins in the helix. When it gets hot it flings the grease.
Right now it is looking like the Tapp secondary is the solution to better belt life. Watched another H2 with the Tapp secondary making pass after pass down the drags. Did not get a chance to talk to that owner. Down fall to the Tapp secondary is you can not run the clutch cover. Evolution Power Sports is supposed to have a spacer kit to allow for the clutch cover to be used.
In talking to the other owners we all love the cars handling, power, and overall driving experience just hate the lack of belt life in the dunes.
Going to take it to the dealer and let them look at the clutches and see what Kawi has to say.
Learning more about the Garmin Tread that comes with the H2 and found this cool power switch Garmin offers to run up to 6 accessories.
Oh yeah I forgot to mention that. It’s a cool feature and could eliminate needing a switch pro. You can also link multiple power switches to the Garmin as they are Bluetooth to the device.
Very similar to the back up camera you can add to the Garmin. To bad the H2 does not have reverse lights, as you could tap the camera power wire into it, and that would trigger the back up camera and turn it on the screen when you put it in reverse.
Have you ever taken a pic with your phone looking down the belt to see where the belt rides on the primary could be an alignment issue between the primary and secondary
