New ride for the dune season - Kawi H2
All done! Not thrilled with the a-pillar light mounts and Baja Designs mounts as there is not enough adjustability to point the lights down more. I will have to figure out another way to mount the lights.
Not having knock outs for the switches just seems like Kawasaki was lazy or cheap. No other explanation for it. Makes adding a switch 100X harder for no reason. Plus you have to be careful and not cut too much.
As far as the lights, I’m not sure why Kawi laid the A pillar back so far? I’m sure it was a “Look” they were going for.
A lighter to heat up a blade makes quick work of the switch blanks.
I think the a-pillar mounts that you attach where the cage is bolted to the frame will do the trick.
Crank down on the mirror adjustment screws really good if you haven't already. Mine felt tight from the box but loosened up pretty quickly
