Can Grok tune an engine?
Goatpoker
Messing around with Grok last night and asked for an ignition table for an LS3 with an LSA supercharger and 9psi boost. Using 100 octane. What do you think of th
looks nice but i wouldnt run that much timing on your specs. even too much for an NA LS3.
Yeah, seems like 32deg is a bit aggressive. But maybe my 24.5 isn’t quite aggressive enough.
my tune anot 10 lbs with a whipple 2.9 ls6 stoker pump gas. i think im alot more conservative than you
Here’s my actual table. Slightly more conservative than yours I think. I’m looking to get more pull in the midrange… which is what I asked Grok to do :)
That is wayyyyy to much timing.
I am at 22 degrees max with 50/50 race.
My tuner won't go above 24-26 even with 100% race.
I’m at 26* all in on an NA car with E85. Grok will scatter that motor on the first hard pull.
Why is timing highest around torque peak, then drops off with RPM? Shit's opposite land...
Sure Grok can tune an engine but can it tuna fish
Asking ChatGPt now. I think it’s a little tone def.
“Your table gives it 16°, which is extremely retarded for that load and RPM.”
28* of timing at 9psi and likely torque peak RPM is wild.
