Temperature difference between upper and lower radiator outlets
Adam G
Just curious what an ideal temperature swing would be between the radiator inlet and outlet. My scenario is a LS1, CBR aluminum radiator with two 12” SPAL fans. Delphi computer cuts the fans in at 201 and out at 185 if I recall correctly. With the engine idling in 90° ambient air, my upper radiator fitting reads 205ish with an infrared temp gun (aluminum AN fittings upper and lower) while the lower reads about 180°. My fans run constantly once the engine reaches operating temperature in this scenario. This has lead to the occasional burned up fan relay. For reference the computer did have triggers for the fans to come on separately, but they have since both been wired together on the cooler circuit. The temp gun on the cylinder heads reads about 187~190.
I’ve never quite understood why people make the On-off ranges so wide. The goal is tight temp control, not a 20-30degree range.
Trying to cool the water from 200 to 185 takes a lot of air. That’s why the fans run so hard. Might consider putting the trigger range tighter together, like 205-200.
Your original question on what is a good delta T for inlet depends a bit on the conditions. 20deg delta is really good. Is that with the fans on? Or just after they shut off? Where the water temp sensor is located has an effect as well. (Note: if you are trying to get the water temp in the cylinder head to 185 and your radiator outlet is 180… that’s only a 5 degree delta inside the head)
Tighter temp ranges makes the circuit cycle more. That is what kills the components. on/off/on/off/.....
  • Like
Reactions: FOG
I don’t have any info on who tuned the computer, or who even built the engine. LS1 block with 243 heads, so I know something not stock compared to the 2000 Camaro the serial number comes back to. I think HP Tuners said the Delphi was from a S-10 too. Closing the temp gap might be a good tweak with the software.
The ~20° delta was with the fans running (they don’t shut off once temp is reached) and it was similar right before the fans came on.
Completely agree with this. Surge current is not nice to electrical components like fans, relays and etc. It’s better to let the fans run for the entire ride than to cycle them on and off several times.
Wire (gauge), connectors and relays were all upgraded before last season and I went through two relays. The fans are new, legit brushless SPAL fans, I double checked and they’re actually 16”. I’m not feeling additional heat from the wiring or connectors, but the damn relays keep melting a pin. I do dune hard with plenty of pepper and as few breaks as I can manage. I have a windshield and a radiator that is pretty low, so maybe the cooling system is just inadequate?
As others have mentioned...
Where is your temp sensor located?
My thought, something else is wrong if you are melting pins on the relays, that is a lot of resistance.
Those 16” fans draw 42 Amps each at 12 volts. What size relay are you using. If you are using a thermostat than your lower hose temperature should be equal to or less than the stat rating.
Must have missed this, it’s in the thermostat housing/ water pump outlet side. The heater loop holes were modified, one plugged and the other has the water temp sensor.
It was wired with what appeared to be Amazon relays. I have swapped both of the originals out with these that say Omron, but came in a Genuine GM baggie. We’ll see how long these last compared to the chinesenum that have melted. I can’t seem to find literature on thr amperage rating for these relays though.
