EmpirE231
- Aug 12, 2021
- 667
- 518
Hey guys... need some help with this.
New to me car was previously professionally wired by (schmitty (sp)?) But I do not have any labels or diagrams. Under the back seat there are 4 relays and 5 resettable breakers. I have not had a chance to figure out where they all go, or if there are any blanks (hopefully there is). Fuses are under the dash. currently what is on the car and most likely running through some of the wiring is as follows
-fuel pump
- 16"radiator fans (2) (come on at different temps)
-GPS
-Radio / intercom
-stereo (pretty sure this is direct to battery though as it has a huge inline fuse before the amp)
-light bar
-front bumper lights (2)
-dual whips
-dome light
I think that is all of it....
currently I am adding a trans pump, and intercooler fans. What is the cleanest way to wire these into my current system (if there are no existing blanks) and what should trigger those to come on? The trans pump has the temp sender wired up, so I would assume it will need its own relay and fuse, should the trans pump be triggered off the fuel pump so that it only comes one when the car is running and has reached the 150 degree temp sender limit?. for 2 10" intercooler fans, would those need their own individual relays or just one, and then fuses... should these also be off the fuel pump, or should I tie them to turn on when the first radiator fan kicks on?
Pics below, not the best.
-fuel pump
-GPS
-Radio / intercom
-light bar
-dual whips
-dome light
