Ok this is bad ass
Uh, no. Steerable axle on the front will absolutely EAT tires. This is an afterthought because is wasn't built right, or was unsuccessfully repurposed...
Competitive used to build all kinds of crazy shit. I saw a stacker they did where they matched the stainless siding on a provost..
RD
RD
Was this before people could do load math? It looks like the tongue has a radial pivot point to allow it to "float" between it and the tow rig. Alleviating tongue weight.
It was probably fucked together to overcome some dudes shitty hitch rating on his old ass bus.
The front wheel arches and the tin work are a scab nightmare of what's underneath.
I am trying to understand the point of the steerable front axle???
Only tongue weight is the tongue itself.
It's definitely weird. I assume they were trying to accomplish something similar to towing a Toad:
Which is rigidly connected in the exact same manner. I don't know of anyone who toads that eats tires though.
The biggest issue with a toad is backing up is basically unpossible. This isn't an issue with a Jeep since you can just drive it. Not so with a trailer.
+1 for Roy's Cafe, Amboy CA on RTE 66.
My sister's Dad (Chip Prescott's Dad, Prescott racing) went to School at the Schoolhouse next door, in the 40's. He grew up in 29 Palms and that was his Playground. He took us to 29 Palms to ride 70's quite a few times, where they still had a 20' x 30' dilapidated Cabin from the 20's they all grew up in. Outhouse, and all.
My thought is they are trying to accomplish something like this and reduce or eliminate tongue weight!
Um...how's backing that thing up???
Well that is an interestingly negative post, and I used my pea brain to think about it for one second.. what about this setup do you feel would not work or even work well?
Let’s see your load math.
Bingo.. the reality is it was more for looks to match a bus than anything else, but there isn’t anything wrong with the setup, I bet it works better than most in all reality.
RD
