LegitDuner
- 2,644
What did you do to the j32 that's making 500 to the wheels? Sounds like a monster. Don't see many j32s with that powerCan anyone recommend a good clutch for 500whp? J32 with 2d
A couple extra atmospheres would do it.What did you do to the j32 that's making 500 to the wheels? Sounds like a monster. Don't see many j32s with that power
The 2 on the front of the valve covers go to the vent canister. The 2 on the back of the valve covers to breathers. I removed the baffles inside the covers.Where on the valve cover did you guys weld the 10AN bungs for the vent lines?
Thanks for the pictures and info!The 2 on the front of the valve covers go to the vent canister. The 2 on the back of the valve covers to breathers. I removed the baffles inside the covers.
Iv had this happen when I had the small plate on. I running without the plate haven’t had a problem. I’m guessing the sand just falls through now. Mine filled up causing the throw out assembly to lock up.Anyone had issues with sand getting into their bellhousing? I spoke with Kennedy and what I thought was clutch dust turns out it is sand getting into the clutch assembly. Never had a problem when I was running a single disc. According to them, Black dust is clutch dust and Grey is sand. Not sure if my adapter plate is not sealing correctly. I always run the small plate at the bottom to seal it off as well.
There are two holes you have to stuff full of silicone. One is in what would be the lifter valley. The other is on the side about in line with crank center.Anyone had issues with sand getting into their bellhousing? I spoke with Kennedy and what I thought was clutch dust turns out it is sand getting into the clutch assembly. Never had a problem when I was running a single disc. According to them, Black dust is clutch dust and Grey is sand. Not sure if my adapter plate is not sealing correctly. I always run the small plate at the bottom to seal it off as well.
Do you have pictures?There are two holes you have to stuff full of silicone. One is in what would be the lifter valley. The other is on the side about in line with crank center.
No, but it's pretty obvious once you get the adapter plate/flywheel off.Do you have pictures?
Do a new rear main while you're in there.found them on my block
Oh yea! All the gaskets and seals will be new. Its a brand new block from Honda with the CSS guards, with the wiseco pistons and P2R rods from the old motor. Should be a tankDo a new rear main while you're in there.
I think 6-7 ha ha. This one should be bulletproof now ha haANOTHER new one? What's that like 10 now? LOL
