MWB
- May 3, 2021
- 3,177
- 3,277
Go talk to the old guys at B&B pools on Baseline & McClintock across from Target right behind Senior Taco. I find those guys to be very helpful.
Lifetime warranty seems to be not my lifetime, as they want about the same to replace mine under warranty. If its a lifetime warranty and parts are no longer available then i believe they should provide a new one and just charge me their stupid $70 service fee. I have to dig out my contract when we had it built 20 years ago and see what it says about the warranty.I was in the same situation with Shasta August 2024. Back then they charged us $1,015 for the 520cc system and kept it on the Lifetime Warranty. System is 4 cartridges as opposed to 8. It works as it should and back up cartridges are less money and less time consuming to clean.
I agree 100%. I'm happy they've warrantied my pool as long as they have. When Leslie's took over I thought the end was near.Lifetime warranty seems to be not my lifetime, as they want about the same to replace mine under warranty. If its a lifetime warranty and parts are no longer available then i believe they should provide a new one and just charge me their stupid $70 service fee. I have to dig out my contract when we had it built 20 years ago and see what it says about the warranty.
Lifetime warranty is never your lifetime, it is the lifetime of the product, determine by them. They still control the end result, sucks but reality.Lifetime warranty seems to be not my lifetime, as they want about the same to replace mine under warranty. If its a lifetime warranty and parts are no longer available then i believe they should provide a new one and just charge me their stupid $70 service fee. I have to dig out my contract when we had it built 20 years ago and see what it says about the warranty.
24/7 everyday.The true question is, How long to you run the pool filter during the day?
Well, if you didn't pee in it, you could get away with considerably less24/7 everyday.
but, it feels so goodWell, if you didn't pee in it, you could get away with considerably less
shastapoolsupply.com
Now this looks like a great idea, just like a Donaldson or S&B particle Seperator for our offroad toys. One concern would be flow and pressure raised due to the extra restriction it adds. Would it put a strain on the variable speed pump?If you are replacing your main filter I highly recommend adding a prefilled. Our new Shasta pool has one and it changed my damn life, only need to clean my system 3 filter twice a year now. During monsoon season it will filter 2 inches of dust each storm. Drain it and good as new.
Waterco MultiCyclone 16 Centrifugal Filter | Pre-Filter 2" 50 mm Model
Revolutionize removing swiming pool dirt and debris with MultiCyclone 16 Centrifugal Filter. Shasta Pool Supply markets the best products that make a different in pool maintenance.shastapoolsupply.com
Our pool has a variable speed pump and it works perfect.Now this looks like a great idea, just like a Donaldson or S&B particle Seperator for our offroad toys. One concern would be flow and pressure raised due to the extra restriction it adds. Would it put a strain on the variable speed pump?
thanks, looks like the pre filter and aquastar 35000 is they perfect combo.Our pool has a variable speed pump and it works perfect.
I just recently made the switch to the variable speed pump, best investment for my pool so far.Our pool has a variable speed pump and it works perfect.
The pre filters are great, if doing the aquastar filter you should have plenty of room to add itNow this looks like a great idea, just like a Donaldson or S&B particle Seperator for our offroad toys. One concern would be flow and pressure raised due to the extra restriction it adds. Would it put a strain on the variable speed pump?
