- Aug 7, 2024
- 1,056
- 1,328
Got a serious toe or camber issue going on.
Can you imagine trying to find someone that truly knows how to do an alignment, in Lake Havasu City?
@RiverDave who does the oil changes and maintenance on that vehicle? That should have been noticed a Very long time ago!![]()
I am going to take it to Tireman after t day to see if it needs an alignment
the one guy that was the goat for alignments had his landlord screw him out of the shop he was in on south side.There is no doubt it Needs an alignment.
Like @madweazl said. Either the toe or camber, or both are out of spec.
The issue will be finding a Competent alignment guy in LHC.
Post up the print out when it's all done.
tireman does alignments but they fucking suck at it. they aligned my work van and they set the toe at 3* toe out (spec is .5* toe in) and it ate the fucking tires in a month because of it.
shit if they had shot for zero that woulda been better than toed out 3 degrees.. i ended up having the ford dealer in bullhead fix it since the ford dealer in havasu isnt worth a fuck either.It definitely takes some time to learn not only HOW to do an alignment, but to understand everything about alignment theory.
Most people just know how to do the "adjust to zero" thing.![]()
