cek
- 250
You can covert it to a belly lift with a little work.Thanks for all the advice. Going to pass on this non belly lift since it also doesn’t have fuel cell and just wait for the right one to come along.
We converted one, it only took about a day, mostly re-cable the lift and move the ramps together.You can covert it to a belly lift with a little work.
Yikes. This is what I was thinking could happen as I put all the weights together.Big picture is coming together. As I said prior, friends is huge and there is a price to be paid. His is a tag axle, and he did rip the hitch off it. Lucky other then some small repair to trailer and rebuild on hitch was all that was needed. Could have been catastrophic.
Exactly. The hitch failed, where the tube for ball mount welds to the cross tube. Broke that tube off. Hitch mount to frame was fine.well as for pulling it with a diesel pusher i would only worry about having a good hitch that is over built not some bolt on hitch that came with the coach have something built. there are pickups that are rated to tow to 20k. pick up trucks are not built nearly as heavy as a diesel pusher and dont have the wheel base to keep sufficient front axel weight also the tires on a rv are usually no where the max rating. even though the rv manufacture puts a low tow rating it is probably only limited by the hitch which can be easily fixed. just my opinion i looked into getting a tag and a bigger trailer a while ago there are very few rv with a tow rating over 10k even on a sparten chassis they are only rated at 10k on a single axel the tags were 15k with a c9 and 20k isx15.
CEK always has the good good stuff. How long is that CEK?Go with a belly lift even if you don’t want one. Easier to sell. You can add sides to make it a platform. Depending on what you need to put in it a 20’ dual axle may do the job and your moho will pull it fine. Ive had traditional lifts as well as the ramp style. The traditional is quite a bit better in my opinion and you can get more in a smaller area. Mine has 100 gallons of fuel. That’s a must for me.
lookmaround at what others are using. There is a reason why they are belly lifts and wide door openings. It’s because they work well and are easily resold.
Trailer is just a 24’ box plus V. Very simple.CEK always has the good good stuff. How long is that CEK?
cek do you know your total weight and tongue weight? A friend is looking to replace his 28ft trailer with a 22' belly lift stacker. They are trying to sell him a 2 axle , has a stnger lift which is heavy and he has a 2500lb car and ~1600lb SxS. I cannot see two 7200Lb axles and 16: tires holding up wellTrailer is just a 24’ box plus V. Very simple.
I’ve never weighed this setup. I think @tjZ06 had a similar setup to what they are trying to sell your buddy.cek do you know your total weight and tongue weight? A friend is looking to replace his 28ft trailer with a 22' belly lift stacker. They are trying to sell him a 2 axle , has a stnger lift which is heavy and he has a 2500lb car and ~1600lb SxS. I cannot see two 7200Lb axles and 16: tires holding up well
Thanks, I know he does not want triple axle, I don't want to be the one sitting on the side of the road with him when he blows a tire due to weightI’ve never weighed this setup. I think @tjZ06 had a similar setup to what they are trying to sell your buddy.
I would guess with fuel, water and tools he would be pretty close to max weight for the trailer. He could go to 8k axles just to be safe.
that seems sensible - I told him 19.5 wheels
My stacker was under-axled, for sure. I did run Michelin XPS Rib tires and had zero problems, and the new owner hasn't had any issues either. If I was building a 2-axle no question I'd go 17.5" or 19.5"s on some 10k axles though. The 17.5"s on my last 5'er TH were 120psi tires with a very high rating too.I’ve never weighed this setup. I think @tjZ06 had a similar setup to what they are trying to sell your buddy.
