This. Has to be ON your lips. Anywhere else and you’re screaming.I have a similar problem. My car is a 4 seater and when someone is in the back, I cannot adjust the squelch enough to completely keep the engine from taking over the audio at high RPM. It is not RFI as was suggested in another post it is sound from the exhaust. I also unplug all other headsets when someone is not using them.
The only thing I have found to help is to place the microphone super close to my mouth (it touches my lips) so I don't have to yell to open the intercom audio with the.
Hmmm. I might try zip tying something solid to the “front” of the mic to see if it cuts down on non voice noise.
Retired helo pilot here.
You had to adjust vox as required. Same in the car.
The best you can do is use the foam mic covers and as ghay as it sounds...press that thing as hard as you can against your lips. I generally open my mouth, press it in my mouth some and then close my mouth. This sets the deek with pressure against my lips and cuts the fluctuations down.
Good call. I have plenty of electrical tape to waste.So my solution was pretty simple. The mic picks up in all directions so even keeping it close to your mouth it will set off from the back side. I removed the foam tip, added a piece of electrical tape to the opposite side of your mouth, and put the foam tip back on. This kept motor noise and wind from setting it off. Not saying it will fix your problem but it’s cheap and worth a try?
I did the same years ago but used Duct tape, and added a larger foam to the mic, or replace the foam every couple of years,Good call. I have plenty of electrical tape to waste.
