JM PRO
- 259
Had a couple board members reach out with some questions concerning my build and thought I would share my experience and hope others will share. Unlike the LS world where there are multiple engine builder resources, we Honda guys don't have much.
I unfortunately have had my fair share of engine failures. They were all preventable.
My first 2 engine failures came from the same issue. I was running a stock engine, aem ecu, 1000cc injectors, E85 and larger fuel lines. 8.5 pounds of boost is all I was pushing. Melted a piston on the second trip. Turns out the stock fuel rails don't flow enough especially using the stock crossover hose. You need aftermarket fuel rails with a proper wye split to give both rails equal pressure. E85 burns 30+% more fuel on top of what extra fuel is needed for the boost setting.
I now run fuel rails from P2R performance with a -8 fuel line to distribution block and -6 to fuel rails.
I have also experienced 2 head gasket failures. Both failures were with Felpro head gaskets. I have spoke with a couple different Honda gurus and they were very clear to never use Felpro. I have since used the factory Honda gasket and so far no issues. The gurus also mentioned Cometic gaskets as a good choice as well but I have not used them yet.
I will continue to add to this thread and encourage anyone to add any helpful info to help our Honda guys looking to upgrade their engines.
