ChasingSand
- 1,011
For the turbo Guys, can you post pictures of your pcv/breather setups? Currently running a -10 of each valve cover but am concerned it’s large enough.
This is extremely helpful! My turbo is still leaking and now also the rear main is leaking. Going to switch to a -12 setup.I've got 3 -12 lines. 1 line is low enough and allows the breather box to drain back into the engine.
I had a smaller breather box before and only 1 breather line. I was blowing oil out of the engine and was blowing oil past seals and dipstick. I have eliminated all breather issues with this setup.
It is a turbo setup. Are your valve covers baffled internally? I am thinking my baffles might be causing restriction.Isn't boost boost? Independent of turbo or SC?
Anyway, I have 2 -10 lines on my setup. 13lbs of boost.
The return line replaced the factory PVC location.
Yes they are, take them both off.It is a turbo setup. Are your valve covers baffled internally? I am thinking my baffles might be causing restriction.
I understand it is a turbo setup, my point was from a venting standpoint, shouldn't matter how boost is made, venting is still needed.It is a turbo setup. Are your valve covers baffled internally? I am thinking my baffles might be causing restriction.
I have the same problem! I do have some piston slap when cold but does go away pretty quickly once the car is warm.When i built my engine, I made a couple mistakes, I bought forged pistons in stock size then had a machine shop clean up or true the cylinder wall. (It had some taper). That made my pistons extremely loose in the cylinders. The manufacturer of the pistons said i was within spec just will be loud when cold. I also made end ring gaps at ,022 and .024" for my top 2 rings. With the combo of sloppy pistons and large ring gap I get a ton of crank case pressure now.
I removed internal baffles on valve covers, removed and plugged stock PVC and run 3 -12 lines from valve covers and I built a breather box that has an internal splash plate and a missive 2" base opening air cleaner. I now have zero issues with oil wanting to escape engine.
Side note- when the motor was bone stock straight from the junkyard, running the same amount of boost, a simple breather box with 1 breather line worked perfectly fine.
Good thing you explained. You for sure have something "different" than most do. So that makes sense with your setup.When i built my engine, I made a couple mistakes, I bought forged pistons in stock size then had a machine shop clean up or true the cylinder wall. (It had some taper). That made my pistons extremely loose in the cylinders. The manufacturer of the pistons said i was within spec just will be loud when cold. I also made end ring gaps at ,022 and .024" for my top 2 rings. With the combo of sloppy pistons and large ring gap I get a ton of crank case pressure now.
Thanks for posting some very good pictures. What is the diameter and height of your breather can? Does the return line go into the bottom of the valve cover? How many miles were on the motor you had the cylinders cleaned up?I've got 3 -12 lines. 1 line is low enough and allows the breather box to drain back into the engine.
