- Thread starter
- #21
Richard h
- 1,323
Fairly simple process to do the reservoirs. Be careful though. If nitrogen has leaked to the oil side of the piston it is possible for the shock to still be charged even though you have depressurized the shock. If you cannot push the end cap of the reservoir inward to remove the circlip than the shock might still have pressure in it. Just something to watch for as even a little pressure in the shock can be very dangerous when you are taking it apart. Fox has great rebuild instructions available on line if that is the brand you have
K, I can't push this in. I released all the pressure from valve. Quite a bit of oil came out. These are piggy back shocks btw. Working on shock shaft to remove. This when I push down it comes right back and there is some pressure on it as well. Idea????
