BRANDON LONG
- 139
Simple rule, if it goes through you then it's safe. Also, no wings or strings.
This is the item that could fail. Ours was transit pipe and it and the j box were completely missing in action after 25 years. Did 2 new lines and j box and this time out of plastic.I have a concrete pad next to the 3 car garage and was thinking of extending it until I found out that is where the field is!
Thanks, not moving full time yet but diffidently on my way! Mom has some health issues and can't leave just yet but will be spending most of my time there!Congrats!
So...lucky, moving out of CA!
:headbang:
:hethan:
to:
Good to hear from Alabama!!! How are you and wife?Congratulations Sir. We have over a dozen properties here and all on septics and have learned a few things. Most of the answers are spot on with the exception of additives. You don’t really need them. In fact if you look at the labels I believe they still say to use them in a properly maintained system. I’ll put it as nicely as I can… only put into the system what comes out of and off of your body. Septic safe toilet paper and septic safe laundry soaps are recommended. ours is always in good shape.
The fact of the matter is tenants don’t give a crap about the rules and flush everything, so the real answer is to stop worrying about it and have it pumped in 3-5 years. Out here it’s not that expensive, about $500.00, compared to the many $1000s to replace to lateral or leach field.
We are doing amazingly other than all the remodels we are doing and trying to keep up with maintaining the pastures.Good to hear from Alabama!!! How are you and wife?
