acefuture
- Jun 8, 2021
- 395
- 678
Time to buy some paddles for my new to me car. I'm going to go 36 STU but can't decide on No1 or No2.
I'm running an Albins AGB with 11.5" R&P, LS3 525 with some work done, but what work is not known. I called redline and they pulled receipts but said they can't confirm on what the build was. Looks like a large cam, and some internal upgrades. Doubt it's punched out, guessing about 600 flywheel (rough guess). Next season I'll pull it and send it in to get a direct answer on internals, as well as put it on the treadmill to see what HP numbers actually are. Car is appx 3600lbs wet. I'm going to lighten up the car a bit for the sand by removing a bunch of the extra stuff for the desert on it like racks, winch, compressor, spares, jacks, etc. That will probably save me close to 500+ lbs. So hoping to be around 3000lbs
What tires are you guys running? Think I should run a conservative No1 or is the No2 necessary?
