Jersey_Jeff73
- May 6, 2021
- 557
- 404
you could use the high beam light or fog lights to power to activate a starter cutout relay
Had a '64 Chevy that had thathad a customer that never used their cigarette lighter (maybe that dates me) but we made it so the lighter must be pushed in all the way, if you pulled it half out car wouldnt run
i i have said before i remove my starter relay and move it to another spot on the main panel, takes 1 min.
Just installed mine. Works great. Relay looks 100% stock and the fob is pretty nice.http://Cyclopsantitheft.com
I have this on my truck. It replaces a fuse and will not start unless you hit the key fob.
Additional fob. You can set it for manual mode (push the button every time) or passive where it “finds” the fob automatically. As long as you keep the fob more than 30’ away, won’t work.Does this replace the factory fob or in addition too?
Just ordered mine.Just installed mine. Works great. Relay looks 100% stock and the fob is pretty nice.
Mine has worked great for several years now, I keep the the stock fuse hidden in the truck in case this does fail at some point.Just installed mine. Works great. Relay looks 100% stock and the fob is pretty nice.
Same here.Mine has worked great for several years now, I keep the the stock fuse hidden in the truck in case this does fail at some point.
Just got my Cyclopse, here is a pic for my 2013 Chevy Duramax. If this works as it should it is the simplest solution to what I was looking for. Thanks for posting!http://Cyclopsantitheft.com
When people ask what you're doing this weekend you can tell them you're installing an alarm in your truck.Just got my Cyclopse, here is a pic for my 2013 Chevy Duramax. If this works as it should it is the simplest solution to what I was looking for. Thanks for posting!
See my last post! Wrote it before I saw yours!!!When people ask what you're doing this weekend you can tell them you're installing an alarm in your truck.
Anybody that knows you will have this look on their face :baby: LOL
I haven't tried the auto mode. I store my keys in a drawer in the front of the house and though I haven't tested the distance yet I wonder if its too close to the truck.Same here. Working great. Had one minor hiccup where the auto mode didn't work, but pushing the button fixed it.
When mine is on my dresser about 60' away from my driveway, it doesn't work. It does work when my jeep is parked in front of the garage and the remove is in the back of the garage.I haven't tried the auto mode. I store my keys in a drawer in the front of the house and though I haven't tested the distance yet I wonder if its too close to the truck.
