Jammer75
- 495
Ecu. Cleaned with soft brush and contact cleaner. See pic. Checked continuity through solder joint and plug on ecu. Checked continuity on male plug and all connections. Replaced relays(needed it regardless). Getting exact same results. I think the tell tale is the fan comes on immediately. I will start checking wires although unless I see something obvious I’m in the dark.I would also thoroughly check the pins on the connector that plugs into the ECM, especially at the crimped part of the pins, and also check that none of the wires are broken internally (inside the insulation) You can check this by carefully holding the wire with needle nose pliers and pulling on the wire to see if it stretches. If it does the internal conductor is compromised and needs to be repaired.
@John@outfront said to. check the two main ground wires from ecu. I’ll check schematic and see what I can find.
I did clean the magnetic crap off both cam/crank sensors and no improvement. Not sure how to test them past that.
appreciate everyone’s help.
