Kraut_n_Rice
Site Sponsor
- May 9, 2021
- 3,545
- 2,805
Ah, the crescent part is inside the gear profile.The belt rides 1/2” more to the left of your line. The pulley fits down in that groove. Pics coming
“Belt is on correctly”. Isn’t the arrow suppose to be pointing up on the crank in this position? didn’t my crank pulley slip in the belt?That belt is on correctly. The early automatic motors didn’t have the Derailer. You must change the oil pump to get the two bosses for the Derailer in your case. The oil pump is $150 for a new OEM pump. We only use factory timing belts $70 and the guide is $15. All in stock
I guess I’m not following. Are you saying that everything is lined up and it’s not the timing that’s causing the no start issue? Ran fine all week, pulled in to camp and parked then just doesn’t want to start for next ride tried starting fluid nothing did notice a crack at weld on exhaust pipe where gas was dripping out when one of the cylinders with wet plugsThere are two sets of marks on a subaru. Lines or arrows. If you put the arrow in the crank pulley at 12 o’clock then the 4 arrows in the cam gears will also be at 12 o’clock. We use the arrows when checking a car that comes in not running because they are at 12 o’clock when cylinder 1 & 2 are at tdc and we can test ghat with a long screwdriver in the spark plug hole. We use the lines when putting in a belt as that is safer (in this position all 4 pistons are 1/2 way down their holes)
Thanks. So earlier in the week, came back from ride. Next morning no cranking. Not sure what but guy came over wiggled trigger wire on imi starter and it started.You understand correctly. The belt is on correctly. Best guess is electric or ecu. What brand do you have?
That’s my project for tomorrow. Thank you sir!Relays triggering/vibrating is not good and is sign of a ground not being grounded. Ecu can get hurt. Typically there is one or two ground wires from ecu that are probably landed on the block somewhere. Look for a broken eyelet or loose bolt
when the friend jiggled the wires at the starter he may have moved the wire harness and a ground was giggled in the process?? good luckThat’s my project for tomorrow. Thank you sir!
Thanks. I do have a receipt from previous owner that he had to send in the ecu for soldering (10years ago) I will definitely check that as well!This is from a Link ECM, note the circled pins. This car was @John@Outfront Shop a couple of weeks ago, and had very similar symptoms.
Here’s a couple pics of ecu. Everything looks good to me. Unless you see something I’ll move on to wiring/grounds/(relays(old and crusty looking)This is from a Link ECM, note the circled pins. This car was @John@Outfront Shop a couple of weeks ago, and had very similar symptoms.
Im Going to go get some right now. ThanksDo you have any contact cleaner? Can you clean the 9 solder joints thoroughly to see if there are any voids similar to what I posted?
