Rockwood
- 6,999
Thrust pretty much murders oil pressure and is stupid easy to check... More of an issue wear-wise with MT cars though since the clutch puts a lot of load on the crank.The Pumps are very different in width and gearotor size - so the dowel idea probably would not work unfortunately. I have plastic shims to set them up - its literally 1 minute of time - since I Mic the crank and bearings and journals and rods and use plastigauge too - the 1 Minute on the Pump is the easy part
I use Clevite bearings almost exclusively because they support builders and have great reps, I sat in on a training they did for old machine shop I was impressed. But they are softer than Kings so in a 30LB+ Turbo I would probabl;y use Kings
I can tell in seconds if the car ran hot - LS bearings are easy to read, but I usually see the Thrust be the issue with aftermarket cranks and most shops (not race builders) never even check
I still haven't installed my LM7, so checking the pump with shims would be easy. Think Melling's instructions are insufficient?
Dowels: Even if they're different width, they all have to line up centered on the crank and sit in a housing of some sort, so the housing casting would carry the onus of lining up the dowels to accommodate. Main gripe wasn't so much there, but front/rear covers and stressed oil pans are dowel'd on every motor I've ever worked on except this guy. Makes it so everything fits together without worry of nuking main seals or cracking Crap because it was out of alignment. I'm sure the lack of location means GM doesn't have to be as close on tolerances for these covers, but it's really annoying for the poor guy working on it. :biggrin:
