J Alper
Site Sponsor
- Apr 30, 2021
- 1,938
- 1,674
When they call me with this issue, a lot of times it is a issue with the bearings, you can try a manual that is the quickest way to check, I am not sure how the motor was built, but really depends on the crank style, the rod style, the bearing style used,
if it has a stock crank with aluminum bearings, i would think the oil hot would be around 30-35, with a 0-40 weight,
DO NOT THROW THICK OIL IN THE MOTOR LIKE A 20-50 WITHOUT KNOWING THE BEARING CLEARANCE, this can cause some issues,
If you are using a stock rod with stock crank, with the correct bearing clearance like a .002/.0023 then you should see 40psi hot idle with a 0-30 - 0-40 weight,
Again what is in the Motor,
What pump, what spring,
This all plays into how oil pressure in a motor
Unfortunately with the LS platform oil pans even if you have bearing material and even a lot of bearing material in the pan, it sometimes will not show up in the oil change, we weld a drain plug with a pocket into the bottom of the pan, this will catch every little thing in the oil,
We spend hours setting up Main bearings, for a LS it has to be correct, or they just do not last,
Couple of things to check
Did the motor cavitate, we had a motor that they thought it had no oil so they put in more oil, this destroyed the pump, looked like it was ran for hours with no oil in the pump,
Was the pump centered to the crank, if not it can damage the pump and have oil loss issues,
and only had this one time, but we had a cracked crank after it was turned and never mad good oil pressure, then a couple trips in the crank broke,
Taking the motor apart, most of the time we can figure out what went wrong,
- pull the side plug above the oil filter and see if the barbell is installed, you can see it or put a 3/8 extension up the hold to see if it hits it,
- pull the Alternator off, pull the side plug off and look for the freeze plug in the front, they can come out,
- pull drain plug drain current oil, and run the lightest weight oil into the motor, with the motor off, into a White bucket and look for bearing material, any material
- find out the bearing clearance, if it is around .00295-.0032 then yes, you can run 15-50 or 20-50
- if a pump relief valve gets stuck, there is a good chance it is because, of bearing failure, not pump malfunction
